PLC Siemens Saphir SIO ACX32 driver for Proface GP-Pro/PBIII; ProfaceGP2400 to GP4400
mihai845
Oct 2020
Romania
Good day,
I need help locating/dowloading PLC Siemens Saphir SIO ACX32 driver for Proface GP-Pro/PBIII.
I am in the process of upgrading a project from Pro-Face GP2400 Controler to Pro-face GP4400 controller and for now I only managed to transfer the backup file *.mem from the old controller using PC tranfer tool and to receive the *.prw file with GP-Pro/PBIII but with PLC file not found.
Now if I try to convert MEM to PRW or PRW to PRX I get the error that Cannot read the source Device/PLC file or Invalid PLC table.
Reason for all these is that GP-Pro/PBII is not having the Siemens Saphir SIO ACX32 PLC in the PLC list.
The same PLC is available in the GP-PRO EX software but that can't be used for GP2400.
Any link available for PLC Siemens Saphir SIO ACX32 driver for Proface GP-Pro/PBIII or maybe another way of converting these files?
Thank you.
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
27
561
Hey guys, I have to take an upload of a program on an S71200 PLC to change a hardware config option and then redownload the program with this...
110
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
357
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
141
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
167
