IGS to Compactlogix L3
Bgardner
May 2016
iron mountain
Hoping someone can help I have been trying to connect to a compactlogix PLC and IGS. I can get data for two reads and then I get bad quality and no more reads CIP Error = 0x00 Ext. Error = 00x0000.
As you have an old version of iFix I'm guessing that it did work at one time. What does that error your getting mean it appears rather cryptic?
What version of Logix ? Newer version allow you to set tag to No Access / Read Only / Read Write.
IGS is just rebranded Kepware OPC Server. You can try to set up another channel to the same PLC using default settings and see what happens.
Where exactly are you seeing these errors? Is it just limited to certain tags?
Did you ever find the solution to this? Having the same issue with IGS 7.5 and CompactLogix L33ER controller. Only 2 reads then nothing.
Hi All, Ive run into an error when setting up my compact logix L30ER(ver 24) on IGS 7.58. This is the first error: "Project correlation error on...
2,922
Hi. I'm trying to update the firmware on some ControlLogix's. They're being polled by an IGS driver. After the upgrade, my floats and integers...
1,384
We have many sites with PLC-5s and 1785-ENET sidecars that are being pounded pretty hard by the GE IGS driver (Kepware) and iFIX/Historian...
980
Hello, I am converting to iFIX 6.1 and talking to a PLC5. I have several TX tags that were looking at N32 addresses in the PLC5 and were getting...
2,919
Hello, I'm looking to setup a test rig in the workshop for testing the likes of the following units; Elau MC-4 Servo Drives & Pac Drives...
1,773
