Which one to use (data acquisition and transfer)
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello All,
This is new territory for me. I have several systems located in diverse areas, throughout the U.S. . They are going to connected VPN to our company server. The systems collect at a 1-second sample rate, with hundreds of tags. I currently have a PLC connected to a RedLion G315C. I am not going to be streaming data, way to expensive, so I am looking at which would be the best option for our remote data collection and transfer, via our cellular connection. I have a little RedLion experience however, for the remote coms and all, over such a long distance, I have no experience. I am looking at all the "Services" the Crimson V3 has and am not sure what would be best for my application.
Our unit is using a cell phone connection to integrate the system in the field, with our company server. The built-in web server in Crimson doesn't work, as it moves data only one direction, besides, I am talking about a lot of data, hundreds of tags. I am using the built-in FTP server on my bench unit however, we will need to go to a historian for this and I am not sure whether I should use the SQL_synch feature on the RedLion, or the OPC Proxy. There are probably obvious reasons why one would work better than another, or reasons why one wont work altogether. I am learning all I can about this, to make a wise choice however, I really am "green" at this and at step 1. I would appreciate any and all advice. Thanks much.
Hi All, I am using an Accuenergy Data Acquisition Server (https://www.accuenergy.com/products/aculink-810-data-acquisition-gateway-server/) to...
2,677
Hi, I am completely new to control systems and PLCs but have been tasked with drawing-up a concept for a new R&D test system for my company - I...
2,835
I have an application that requires high speed data acquisition. We are looking to capture data once every 10-20mS. This is for edge computing...
6,682
Dear friends, I need to access the data of various energy meters connected to Allen Bradley PLC. My general approach to access data from any...
2,418
Hi! We have a custumer with ~70 ABB robots (from S4 -> IRC5). They have asked us if we can gatther data from each robot (measure uptime and...
2,585
