Making a connection between Productivity 3000 and AB 1734-AENTR Remove I/O
xinlu8439
Apr 2017
philadelphia
I currently have a project that needs to use AutomationDirect Productivity 3000 PAC to communicate with Allen Bradley 1734-AENTR remote I/O module.
I don't have any AB PLCs, or RSLogix 5000 programming software, but I do have Wonderware Intouch available.
Productivity 3000 PAC has the so-called "scanner" feature, so that I can simply create a generic scanner client to retrieve 1734 data.
However, by following this doc: http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1734-um016_-en-p.pdf
I didn't get the luck to make them connected.
On my scanner configuration, I put 100 as the Assembly Instance under T->0(Input), and 101 under O->T(output). Is this correct? I am confusing actually.
The PDF says I don't need a configuration header to make a connection. No matter I create this config file or not, I always get the following error:
Connection Resonse: True
Connecting Device: 1734-AENTR/B Et (seems they did exchange info once)
RemoteI/O Online: False
RemoteI/O Status: 1
RemoteI/O Status Description: Invalid segment
Is there anyone got expedience to set up this 1734 remote io?
Thanks a lot!
Hi I have a CP340 connected to a balance. Balance to hyperterminal works. Balance to CP doesn't work, RXD blinks, but no data retrieve Any ideas...
2,932
Hi, I have seen a few post with similar topics and I have tried contacting the authors however I have not had any luck so I am posting this new...
1,010
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,511
Hi all, I have been working on a tool for my company that handles a specific task our company runs into often related to PLC's. This is a tool I...
2,874
Hi, i need to make: 1- A PLC Program on Omron PLC CP2E-N using high speed counter E6C3-AG5B 360P/R 2M(Absolute) ,to Reject bottles on Conveyor...
877
