Do you think which software is very nice for design control panel?
Platootod
Jan 2003
Mechatronics RIT.Non
215
Could anybody reccommend some software for design control panel.
Also, IEC standard for instalation equipment (PLC,Busbar,Magnetic,Circuit breaker...etc)inside control panel.
Thank you very much in advance.
I knew some but may be your's advise better.
Platootod
Rswire
All I have used and played with, I have found that RSwire is the best interfacing software I have ever used.
1. It infaces with Autocad
Once drawings are made, anyone with autocad can work with the drawings
2. It can cme with a version of Autocad so you do not have to purchase the full blown Autocad
3. Has many many standard core racks, switch gear, busway etc... The drawings it developes are all industry standard
4. Natually, there are added bonuses when using Rockwell software for PLC. Such as it will interogate the PLC code, comments symbols and descriptions and build a project with drawings, terminal strips, wire numbers, MCC, motors etc...
5. It has been out for quite some time
I need to change my program to increase a IP transducer by 0.5 psi every 5 seconds. I am making a automated pressure tester using a pump, IP...
1,045
My hard drive crashed on my PC that I was running an old version of Concept. I still have the installation disk but do not have the activation...
1,344
For anyone who needs it Horizon Data Systems just released a home version of their rollback RX product for free...
4,482
Hello All, My company is looking for a software package that will enable us to present a nicely packaged, professional looking, project archive...
3,101
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
114
