High Speed Counter on FX0S
sara
Oct 2004
Hi, me again!
Having quite successfully programmed a nice sequence into my PLC for a stepper, I have now been told that we need more user interaction, i.e. they can interrupt the sequence and start a different motion.
This is fine but I need to be able to tell the stepper how to reset itself. The problem I have is that this PLC is too old a version to have a pulse counter included on board, so I've had to wire the high speed output to the high speed counter intput. The high speed counter doesn't seem to be able to give me any value.
Ideally, when interrupted, I could take the value from the counter, reverse the stepper, and tell it to send out that many pulses again. But I only get a 0 off the counter, even if I try to MOV its value to a register or ADD it to another.
Is there a way to do this?
Thanks,
Sara.
The high speed counters start at C235 (For X0)
But X0 will not show in your logic (in fact it must not)
You can use the 'always on' bit to enable it or anything.
(These are 32 bit counters - so to move the value would need double word move)
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
73
i am bench testing a 1734 -VHSC24 Point I/O High Speed counter module, i cannot find any examples of wiring the outputs from the module. does...
1,362
Hello guys, I have created a program where I count the high speed inputs of a flowmeter and create pulses per second to check the flowrate. Next I...
1,773
Hello to all, I don't have to much experience in the PLC. I'm using the Studio 5000 v32.03 We are trying to measure the length of a product, in...
1,116
Does anyone know how to set the output window on-off values on the fly without having to inhibit the module? I could of sworn when I first started...
2,373
