Indexing Source and Target address in the PLC5 MSG Instruction
May 2002
I'm trying to use only one Msg Instruction where the Source and the Target addresses are Indexed (Dynamic), i made that using an Integer (N) file address in the Control of the MSG instead of using the (MG) file address.
The code work's fine for the indexation but i still have a problem:
How can i define the Port Address for the DH+ network using the (N) file address ?
Maybe by default it's not possible to send messages out through other port than channel 1A.
Can somebody help me ?
Thank's for your time,
Walter Moreira
From RSLogix 5 Help file:
MSG - Message Instruction
Using the MG control block, the control block size is fixed at 56 words. You must use the MG control block if you are sending messages to an SLC 500 processor using the SLC read and write commands, or if you are sending messages out any other port than channel 1A.
© 1997 Rockwell Software Inc.
Why are you trying to do this? Why not just create all the possible MSG instructions you need, and enable only those you want? I'm fairly sure that Rockwell warns agains indirectly (or indexedly) addressing data in MSG blocks - although they don't say why.
They do say:
You cannot use indirect addresses for the control block address in an MSG instruction. If you have an MSG instruction created with version 3.21 or earlier that uses a control block with an indirect address, you must delete the instruction and re-enter it without an indirect address.
- Instruction set manual, p. 16-3
Remember that the MSG is asynchonous to scan (although it may be triggered synchronous to scan). Changing parameters while the MSG is still "in motion" could bring trouble.
Hi, I'm trying to use only one Msg Instruction where the Source and the Target addresses are Indexed (Dynamic), i made that using an Integer (N)...
5,873
Hello, I'm in the process of converting a slicer from an Ultra3000 drive to a Kinetix 5100 using the KNX software version 4.00. The current...
528
Hello! The equipment I'm working on uses a lot of indexed tags I guess you'd call them. I thought it was indirect addresses maybe but all the...
1,044
Hello, Please see the attached rungs of some sort of indexed sampling routine that is currently in a SLC500. I am tasked with migrating to a...
1,281
Hi everyone. Been banging my head against a wall trying to figure out tracking on a servo driven conveyor. I already have a tracking array setup...
3,402
