modicon quantum controller
srik
Sep 2005
hyderabad
104
I worked earlier in a company which is having Modicon quantum PLC.
The CPU is 140 CPU 43412A.
Now there is a problem,the CPU get empty.So they have loaded the program using Concept V2.2. Adialogue box appeared after successful loading, down load completed successfully, start controller, clicked on Yes button. But the controller is not coming to start mode and now the controller status is showing “unknown controller''. I sugested them to check configuration for PLC type.But it is same as actual controller.
Please help us to solve the problem.
Have you loaded an executive? This is the operating system that the PLC uses to run the program that you write. The executive files are found in the Concept Execloader.
Hello, I'm trying to access a quantum PLC using ProWorx. Network explorer can find it on modbus plus node 12 but it's status reads "BUSY...
4,445
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
259
Hi There, I have a Modicon Quantum PLC, there is a alarm on display "noConfig" its happened after power failure, I have gone through manuals...
652
When i read the specification of 140CPU43412A i observe that as remembered in specification 1. Local i/o : Maximum i/p and o/p words are 64 in...
496
Main rack contained power supply 140cps52400 and 140cpu43412A and RIO HEAD 140CRP93100 in addition to another I/o cards . Another remote rack...
1,860
