connection between RMS controled by PLC and DCS control room
DeltaX
Aug 2008
Tripoli
Hello every body,
For power plant station, there are RMS "Reducing & Monitoring Station" controled by PLC Siemens S7, and the main control system for all the plant is DCS.
Now if we need to connect the RMS control system with DCS BOP control room, from my understanding "plz correct to me if I was rong" there are two ways, the first one connect for monitoring and the second one for monitoring and control.
The distance between the RMS control station and the DCS control room is more than 600m.
If we connect the RMS control system with DCS BOP control room
for monitoring and control and maybe for protection either, is it necessary to use hardwired for this connection or fiber obtical can be used for guaranteed.
for monitoring only is't possible to connect it by means of serial communication, RS232 MODBUS for example, or we have to use the fiber optical.
Your help is highly appreciated.
Thanx for any help
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
298
Dear all, I have fx3u series plc with built in rs422 port and usb-sc09-fx cable. I have a a hyperterminal like application to send and receive...
222
Good Morning, I got an IMO HD2 inverter with 2 slots and on the first slot I put the ethernet module (HD2-E-ENET) and the second one is free...
1,260
Is there any way to make a connection directly between a GE Fanuc 90-30 and a Mitsubishi FX Series PLC? If there is no means to connect directly...
21
4,205
Hello, I'm gonna try to make this as clear as possible. For a project, we have 3 Unitronics PLC's controlling each a machine. The company that...
3,407
