Prroblems in connection between CQM1 CPU45 and computer
Ana
Feb 2004
Hi!!!
I am working with a PLC Omron CQM1 CPU45 and, in an unfortunate way, have erased some directions of memory (among them the DMs). After this one erased it has turned out that whenever I am going to try to connect to the PLC with the command 'connect' in Syswin 3.2, does not allow it to me sending me different messages,among them: ' incorrect FCS ' or ' received head-board not been worth ' or ' the connection has not taken place with the PLC '...
I have tried to verify if the connection across the serial port was damaged, opening the hyperterminal for the port selected in the PLC and, as result, have verified that the PLC is Sending constant something as ' @00EX146700 ... 00575B ' where they are in the habit of changing the last 4 numbers occasionally (they are the FCS).
I would be grateful much if someone could tell me what is happening and how I can arrange it to be able to establish again the communication with the PLC.
AH! Forget to say thatI have already tried to put the dip 5 of the CPU to ON to re-establish the connection for the serial port, but it has not served for anything, the connection has continued without re-establish
Thank you very much in advance.
Anna
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
213
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
433
Not a PLC question but I need expert help on this. My FactoryTalk stopped communicating with the server its hosted on. I had an error stating...
83
I have to start out by saying I am not a PLC programmer and I have basic programming skills but mainly use software as a troubleshooting tool. I...
113
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
146
