can you specify bits in omron PLC's
Jan 2011
sunderland
hi there can anyone help.:unsure:
When using a mitsubishi PLC you can specifiy bits ie
k1= 4 bits
k2= 8 bits
k3= 12 bits
k4= 16 bits
so if you wanted to move only the first 4 bits on channel y40, you could write [mov k1y40 d0]or [mov k1y48 d0].
So my question is, can you do this with omron plc software.o_O
thanks lee:nodi:
You did not specify which model Omron you are using.
There are some differences based on model.
However, the MOVD (Move Digit) Instruction has been around for a long time and should work.
The trick with MOVD is the control word.
Please take a look in the Programming manual for your model and it should help you.
You will need to download the W340 manual.
This is the programming manual for CS1/CJ1 processors.
The control word in the instruction indicates which digit(s) will be moved from the source word to the destination word.
See attachment for more information.
many thanks i have managed to get it working, my aim was to use the plc's clock address a351.00 and so on the first 8 bits signfiys seconds and that last 8 bits signifys minutes so wanted to but them seperatly in to their own data memory. it works but its a bit long winded mitsi is far easier.o_O
thanks alot lee (y)
I use both and do not agree. I also use masks extensively (ANDW) and this makes life extremely easy.
It is always hard getting used to a different brand by the waY.
Rockwell Software Studio 5000 View Designer v6.01: Is there a way to limit the number of digits of a REAL tag that get shown in a text display...
1,878
How do I specify the amount of screen opened by OpenPictures? I have a problem here that I need to open the screens of my top menu with...
1,620
Is it possible to use a MOVE_INT block to initiate a subroutine CALL block? for example, i have several CALL blocks and i want to use a MOVE_INT...
2,190
I mean we cannot depend on the contactor that let the pump/motor on or off because the motor/pump may fail and the contactor is still working ...
4,399
Hi I am being given several fault words (as a DINT) from a Drive that I am receiving into a Compactlogix L33ER controller. I have a small...
1,140
