Factorytalk SE
randheerp
Aug 2006
Bangalore
77
I am experienced in iFix SCADA but new to Factorytalk SE SCADA.
In iFix we can write script in the Scheduler (Which can act as a global script) to store Tag data in a Database (Using ODBC) and use scheduler properties.
In Factorytalk SE where can i do this? See, I can see a platform to write script (VBA Script) under a display page, but cant find a place to write a global script.
Is this achieved in Factorytalk SE using Macros?
T&R
Randheer
Hi.
Have a look at the DATALOG file option. You will need to make a DATALOG file, and then set it up to use ODBC for storage. Add the tags to the model.
Make sure to turn the DATALOG on with the command "DataLogOn Filename" (I run this in a startup Macro.
You can trigger snapshots with "DataLogSnapshot Filename" to act as the trigger, which can be scripted wherever.
If you want it scripted in VBA it would be"
ExecuteCommand("DataLogSnapshot Filename").
Hope that helps.
Thanks Commando.
I tried DATALOG file option and its working.
To be precise, i want to know where i can write a global script in FTV SE?
Thanks Commando.
It depends what you want to do.
You can run an EVENT file that will execute things "globally" (from the server). However, lots of commands CANT be ran - because they don't know where to execute. Example - "Display XYZ" can NOT be ran from an EVENT file because it doesn't know where to execute.
Generally I have a "background" screen that runs on all clients that is cached and running in the background.
To your startup macro add the following:
Display BackgroundScreen /ZA
Then have all of your code on the BackGroundScreen.
Hope that helps.
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
155
Rockwell Tech Support seemed to have hit a wall with this question. Already updated the version to 5.00.13 per their suggestio but am still...
68
I can't seem to get the Panel View Plus 7 standard edition to downgrade to V_11, when I check the AB downloads and compatibility websites for this...
98
Hi, I'm trying to export data from a DataGrid to Excel using VBA, but I'm getting an error "Object doesn't support this property or method". The...
63
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
76
