Allen Bradley Micro830 modbus RTU and yaskawa j1000
illibilli
Apr 2016
horsens
Hi guys.
I have a some-what noobish question. I have been doing light plc programing for the last year or so, mostly with descreate I/O's, simple stuff, timers, solenoids and so forth.
Now I was asked to make a simple variable speed control system for conveyors.
The conveyor motors are powered by a yaskawa j1000 VDF's and the comunication between the VFD´s and the Micro830 PLC is Modbus RTU.
I´m using a POT for the analog input on the Micro830 (expansion module) and it has been pretty straight forward in regards to scaling the signal.
But I´m compleatly stuck on how to set up the modbus in the PLC.
There is a function block called MSG_MODBUS_1 in the CCW software and I´m pretty sure that it is the one to use, but that is as far as I understand this.
I have been reading the manual for the yaskawa j1000 modbus comunications and it is all there, but I just dont know on how to use those informations.
Is there anyone here that has configured a micro800 to yaskawa j1000 that can just give me a little help.
I have several Micro(820) communicating with Schneider Altivar 630 drives using
Modbus(Tcp).
I would be happy to share my program(My Communication Module) should you want to study it.
Modbus(Tcp).
Hello Damica,
I read you have expierience in Micro820 to Altivar630 over Modbus TCP, could you give any tips please?
Thanks in advance.
HI – I need to generate variable -10vdc to +10vdc output to a kinetix3 drive from a micro830 PLC. I have a 2080-IF2 and a 2080-OF2. I will have...
4,544
260
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
81
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
429
Hello, I am new here. I am trying to find good places to sell some surplus items that I have that isnt through ebay. Does anyone have any sources...
354
