Read Tag comment during runtime in WinCC Flexible
RammRras
Jun 2015
Italy
I am trying to find out if there is a way to "read" the tag comments in WinCC Flex 2008 (SP3) during runtime.
I'm using WinCC Runtime on normal PC.
I'm sure that the comment is saved in WinCC Flexible becuse my HMI is integrated in Step 7 and I see that the Tags are created and linked to those of PLC. But I'm not able to acces that information during runtime for example via Script. :mad:
Many Thanks,
Any advice or information would be appreciated
As far as I know, tag comments are only in the engineering, and not in the runtime. However, I've seen people do things like export their tags, and then import the comment text in via a script and a text file on the HMI. I don't have a sample program, though.
Thanks for the reply mk42,
I also thought about doing it via script.
and it was also my fear!
It would have been nice if it was a property of the TAG usable in runtime, but Siemens did not think that could also be used to be displayed as well as provide project documentation.
Dear colleagues, I am reaching out for assistance with an issue I am having. I have a code that can successfully insert data from FactoryTalk...
1,049
Hello expert; I want to read the tag values from control logix plc over the WiFi connection. I did it by using Rs link OPC and successfully read...
1,166
Read Tag from Rockwell PLC from Codesys 3.5? Rockwell PLCs would be 5370s, 5380s, 5570s, and 5580s etc. It seems everyone's EtherNet/IP...
73
21,199
Good Evening Gentlemen, we have a FT View SE client running in windows 7 system, now I want to update that system with windows 10. I did the...
2,718
Hi, I'm pretty new to FactoryTalk and PLC's in general. In View SE, is it possible to read a string contained in a UDT and use it in another tag...
1,231
