Siemens Laser Scanner LS4-4 AS-i Version
pboll
Nov 2005
Beijing
16
Hi everyone,
I'm using Siemens LS4-4 PLS which is AS-i Version, it's working, but the problem I have is I cannot get the warning signal.
I can see the amber light came on when there is object in the warning field. Occurding to the manuals, the output of the warning signal is thru AS-i. I'm using CP343-2P as AS-i master, but I cannot get any othing other than e-stop (cut-off the flashing signal).
So what I'm thinking is maybe I need to setup AS-i for the PLS. But how?
Is there anybody have some experience using this one?
Im not much help
I have used AS-I one time before but with different hardware. I had a Profibus AS-I master, e-stop, safety gate, etc. Each safety condition (e-stop, safety gate) has to have a safety output. The only way I could get the status of each condition was to assign a non-save output to the condition then bring that into a input on my plc.
I am not much help but there are a few more people on the board that have used AS-I and may have better ideas.
Good Afternoon , It has been decades since I have done anything with Siemens . What is the Siemens name of their Servo Product Line and what...
105
I'm using the Siemens PRONETA software to do some IO testing currently. I love the simplicity and fast testing capability. Does anyone know about...
81
Hi, First time user of S5 Siemens. Is there any solution on how to solve this kind of error. HMI OP7 $613 DB-error No. 11 (0: 15) Siemens PLC...
169
192
Hi all! Please inform me if i can make programing of the HMI SIEMENS IPC477D from TIA Portal software or not? I do not have WINCC software but...
110
