VMWare workstation Version 7
Operaghost
Apr 2002
Dallas, TX USA
4,107
So is anyone using this yet? I see it supports Aero. $99 for an upgrade from my v6. I think I have to have this!
Curious if it can boot from a USB drive yet. May have to download the trial and install on a clean machine.
OG
Prior to Workstation v7, the virtual chipset has been based on the Intel 440BX. Unfortunately, that chipset does not support USB as a bootable device since bootable USB came well after the 440BX. When you enter the BIOS you cannot select USB as a boot option.
Now, there are workarounds where you can essentially trick the system into recognizing the USB drive as a physical drive. But that opens a can of worms I don't want to get into. I need to use a USB flash drive, not a hard drive connected via USB.
I need to prepare screenshots and video clips demonstrating using a bootable USB flash drive. Faking out the system into recognizing my flash drive as a physical hard drive defeats the purpose of what I need to document.
I have downloaded v7 but haven't installed it yet. Not sure if it is still based on the 440BX or if they upgraded the chipset.
Also, booting this way this does work on other VMWare products, but has been a limitation of Workstation.
OG
You can, and it doesn't know or care. But....you have to trick the system into recognizing a USB drive (flash or other) as a physical drive instead of as a removeable USB drive.
I am trying to document, with screenshots and/or video tutorials, the procedure for setting up a PC to boot from USB. VMWare has a nice movie capture feature that works great for what I need but when I enter the "virtual" BIOS, there is no option for selecting USB as a boot device.
I'm just trying to find out if v7 has improved this procedure.
OG
Hi guys, I am trying to use VMware workstation 16 player to configure RSlinx but have run in to all sorts of issues. 1. Not able to configure...
2,546
Hello Everyone, I know there are a couple of threads on VMWare and Rockwell, and it has been discussed before, but I was hoping someone could...
1,867
I'm currently trying to setup a VMWare Workstation VM for Rockwell PLC's I would like to have RSLogix 5 v10, RSLogix 500 v12, RSLogix 5000...
3,380
Hello Fellow Techies, I was wondering if anyone had a good setup from Host to Guest wrt network configuration. When I use the ME Transfer, it...
1,011
Hi, This is new to me - I used to connect Rockwell software thru Ethernet cables, now we got a router attached to the PLC. Having hard time to...
3,365
