Problem connecting Weintek HMI to PLC using Modbus TCP/IP
TahirQ
May 2013
Riyadh
54
I am using Weintek MT8100i HMI and Schneider Modicon M340 PLC. In easybuilder file, I have Defined the PLC as Schneider Modbus TCP/IP type. Now when I connect PLC to Weintek HMI using ethernet crossover cable, neither the PLC is detecting the HMI nor is HMI getting any response from PLC. Has anybody ever encountered this type of problem before because I am doing just as weintek manual and PLC connection guide says still there is no communication between PLC & HMI.
I have done exactly as the manual says about adress formatting which is also in PLC Connection Guide of Weintek HMI's. Still I can't seem to trace the root of the problem.
One thing I noticed in those instructions was that it said some devices require a straight cable instead of a crossover. It sounds a bit strange, but you might try that just to see if it works.
Hi TahirQ, I have exactly the same problem with the same plc and hmi. How could you solve it?
Thanks a lot!
I have the same problem, whitch version of EB pro that you use.
First of all Hi, nice to met you all. I have a problems trying to control my PLC's (1762-L40BWA ser. C and 1763-L16DWD ser. B) with the Panelview...
4,998
Hello! We have one Omron NT11-SF121B-EV1 display and CP1L PLC. I want to connect this display to computer and upload graphics with NT-series...
2,307
Greetings i do have a new Siemens PLC station with 314 CPU 1DP i try to connect using the PC adaptor Cable USB A2 i do have the Error message...
2,224
Hi all Was wondering if you guys were able to help. I am onsite trying to program a 440C-CR30-22BBB Safety relay. Using the following pdf and...
4,331
Dear Members: I am new to Twincat System. I am working on a project. I have connected CX9020 with my laptop through ethernet cable. I was able to...
4,571
