PLC S7300 Bus Connector
g_simons
Guest
G
Regarding the S7-300 racks I am not sure whether I must acquire a bus connector connecting the I/O modules to each other, or the bus connectors are not necessary due to the integrated bus housing.
Frankly speaking the sentence "The backplane bus is integrated into the module. Interfacing with the module is via bus connectors which are inserted into the rear of the housing" mentioned in the Siemens catalog, does not give me enough clues if I must purchase an individual bus connector (Which its code order is still unknown to me) or I can be sure about the fact that the I/O modules have their own integrated bus connectors and does not need any further ordered component intended for connecting I/O modules over the DIN Rail.
It would be your kind attention if you assure us about the lack of necessity for bus connectors or let us know about its proper code order
A bus connector is always neccesary, however normally it comes with the i/o module (see catalogue ST70) if you need a spare part the code order is 6ES7 390-0AA00-0AA0.
This only goes for an S7-300
To be or not to be, is that a question???
As was stated above the connector comes with the I/O devices with a S7 300 system. The Din rail to mount them on is sold separately.
Hi All, I want to know the steps to create BUS Fault in S7 300 PLC. I have profibus MPI Cable connected for communication to the PLC. Anyone have...
3,238
Hi Any one here please helpmein simulation of s7 300 plc program with factory io. how to connect. plcsim 5 doesnot have option of s7 300 ..:
1,009
Hi I want to read degree from absolute encoder 1024 binary by plc s7300. Please Describes the functionality of the absolute encoder 1024 binary...
4,384
Hi all, I am tasked with quoting a solution in which our two S7300 PLC's with added 343-1 LEAN CP is supposed to communicate with two WAGO IPC...
2,956
I have got a PLC S7-300 communicating to a device running Profinet IO. I have a shared data block (DB1) with few attributes. I want to know the...
1,924
