Micrologix 1500 and USB Port Comm problem
sandymax
Nov 2004
India
112
Hello all,
i am facing Communication problem bet AB Micrologix 1500 and laptop , my laptop is having USB port , i have conform with Computer
Counsultent that USB port is working properly
i am Using DF1 Comm driver
What Important setting needs to done so that i can Go online or Download Program.Pls help me, i go through the Older Forums but not find any Much help
Project Specification
PLC : Micrologix 1500
Cable 1761-serial-pm0d
sandy
Have you tried the autoconfigure in RSLINX to set up the driver for you?
Sorry, I just checked the link that mgvol provided and it says that the autoconfigure is not supported for USB. It does provide the settings for the DF1 driver on that link.
79
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
103
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
917
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,204
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,425
