Pro-face Factory Gateway Protocol
rhung
Oct 2003
We have an Unix application needs to communicate with a number of PLCs with serial interface thru Ethernet. Each of these PLC connects to a Pro-face Factory Gateway unit (FG), and all the FG units are connected to the plant's Ethernet network.
We need to know the TCP/IP protocol of the FG units so that our Unix application can communicate with them. But we couldn't get a straight answer from Pro-face. Someone told us that it is a proprietary protocol call Memory Link. There is a document on their website describes the Memory Link serial protocol for their operator panels, I'm not sure whether they use the same protocol on Ethernet for their FG units.
Any help will be greatly appreciated.
Maybe a clue to help yourself would be to look in to how / what is communicating to the gateways in the current configuration.
Is there a serial connection between each individual PLC and each gateway?
What is communicating via your lan to the gateways?
The Factory Gateway units are like terminal servers that convert serial protocol to Ethernet except they understand the serial protocol of the PLCs and convert the serial protocols to their own proprietary protocol.
We have their operator panels connect to them thru Ethernet (LAN).
If this is proprietary, then there is no other place to get it from than Pro-face. Legally, I mean.
If they are not willing to disclose it... well, you would have to find something different to do.
I have a GP37W-LG11-24V an old unit with a round ps2 looking port for programming. Does anyone know the part number for the cable is and what the...
239
Hi All, At site, there is a Pro-Face 19” screen Model: SP-5800WP FWXGA complete with PFXSP5B10 box. Connected via Ethernet to the screen...
3,108
Good evening, I have a problem with PLc schneider Pro-Face LT3201,it does not start,I dont know which software is used to communicate with...
1,025
Has anyone ever seen this on a Pro-Face HMI? Im using a SP-5400 screen with the SP-5B10 brainbox on the back. Anytime there is a power failure...
852
My Winter project of revamping a plastic sheet extruder is starting to progress. I stopped by the customer on Friday and looked at the Davis...
17
6,561
