panelview plus 1000
Here is a little more detailed description of the process to convert a .mer file to a .apa.
Create a new application in RSView Studio with the name that you want to restore your .mer application to, for this example let us use the name “Restored App”. The new application is stored at: “C:\Documents and Settings\All Users\Documents\RSView Enterprise\ME\HMI projects\Restored App\”
Upload the .mer file from the panelview plus using the file transfer utility provided with RSView Studio. Run the uploaded .mer application on your PC. You will get a warning most likely that you current license will only work for two hours, then you will get a warning stating that you have too many screens to run on your current license. These warnings are fine this will still work. Anyways, once it has been opened it extracts all the files from the .mer file into the following directory: “C:\Documents and Settings\username\Local Settings\Temp\~MER.00\”
Select all the files within the “~MER.00” directory and copy them into the “Restored App” directory overwriting all the files in the “Restored App” directory. Now go and open the RSView Studio and select Restored App. Like I mentioned before you will certainly lose the alarm messages, but you can open the M_Alarms directory and read the MachineAlarms.mal file in notepad.
I have an unrelated question about uploading a .mer file from a running touchscreen and converting it to an .apa file that can be restored for use in RSView Studio
The next release of RSView Studio ME (CPR9) is scheduled to include a utility that will allow the upload of a .mer file and conversion to .med.
The software that Rockwell is calling (among other things) "CPR9" is due out this fall sometime. They'll have a better schedule announcement in June at the RSTechED event.
*.MER -> RSView Studio project conversion will be done by the Application Manager, just like restore and backup and archive functions are now. When you create a runtime, you will have the option of making it extractable Always, Never, or with a password. This will help protect OEM intellectual property and also allow for the more common circumstance when the project file is lost or unavailable.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
129
Hi everyone, I've been tasked with creating a basic HMI for commissioning purposes for two pumps on a AB Panelview Plus 1000, 2711PRDT10C. I have...
2,884
im tring to find out if i have a bad power supply for my panelview 1000 plus. does anyone have the pinout for the 10 pin connector on the...
1,854
I need an X/Y plot to visually represent data o a roundness gage I am designing. ActiveX ME Chart Control UDT seems broke. Any advise one how to...
659
Hello Everyone, I hope we are all good today! I have a project from 2015, and the customer is locked out of the HMI. They do not know what the...
1,960
