Can we use ControlNet & DeviceNet cable from Belden/Kerpen?
flyers
Sep 2006
Amk
295
Hi guys,
Need some advise from you guys, I wonder if I can use Controlnet & DeviceNet cable from 3rd party other than Rockwell Automation? 3rd party like Belden or Kerpen cable. This is to save some cost on the project ;)
Does anyone have the spec of the CNET & DNET cable from AB?
Thanks a lot.
Yes, you can use another brand cable. Just make sure it is conformance tested by the ODVA and Controlnet Organization. Do NOT just an equivalent looking cable.
I would always use the Grey PVC Belden DeviceNet cable in preference to the yellow rubber sheathed AB cable. Lapp's very flexible cable is better than both but it is quite expensive.
Andybr
Hi guys,
I've tried to source for Belden cable to replace the cable from Rockwell, but it seems it's more expensive than Rockwell, I got a shock!
Hope you guys can let me know if I'm looking at the right cable.
1) Belden 3083A = Rockwell DeviceNet round thick cable (2x signal, 2power, 1x shear) - 1485C-P1-A500
2) Belden 3092A = Rockwell ControlNet RG6 quad shield coax - 1786-RG6
Thanks.
3092A is the ControlNet cable I usually use.
For Devicenet, I use 7896A, which is 600 volt, ODVA Class 1, 8 Amp rated cable. If I do not need the 600 volt insulation rating, I use 3082A, 300 volt, 8 amps ODVA Class 2.
Guys,
Thanks for your info, we decided to stick back to cables from Rockwell, due to some tax exemption stuffs. It'll be additional hassle if we get from too many supplies instead just Rockwell alone.
Does anyone know of a cheap USB to ControlNet or USB to DeviceNet adapter (I'm looking for both). I thought PLC Cable would have one but I did not...
2,241
I have a Devicenet network that has about 12 Toshiba VFDs that intermittently drops out and the operators are able to immediately re-start the...
1,898
We have a few systems that use DNet and CNet. I noticed there were programs called RSNetWorx which after checking out I see is a topology tool...
3,784
Gents, I have a problem when I want to use the device bridge 1788-CN2DN (controlnet to devicenet). I just wanted to know if someone in here had...
2,649
1,474
