Non - AB Protocol Send / Receive on Ethernet in SLC / CompactLogix
PMCR
Jul 2005
Philadelphia
62
Is it possible to send/receive non - AB protocol commands on Ethernet from a Compact Logix, MicroLogix, or other processor? I have looked at the MSG instruction, but this does not seem to support non - AB protocols.
Specifically, there is a 3rd party RFID controller that uses SQL commands over Ethernet to communicate with the RF tags.
I am used to the 'Socket Services' function of the Omron CS1 / CJ1 ETN21 modules which support this function, and I cannot find a similar function in AB.
I have writen a serial driver for the Mitsubishi QJ71c24n-r2 module. The driver controls a pump, that requires serveral commands. The software has...
3,582
if we need to take back up of Siemens CPU(s7300 /s7400) with non siemens slave profibus nodes without their gsd files and when we restore it in...
67
Hi all, I have installed a SICK AFM60A-S4IB018x12 encoder to Allen-Bradley CompactLogix PLC and configured its parameters via AOI provided by...
82
Hi, I'm trying to understand a couple of things with a feedback signals that are used in a SRP/CS that I'm working with. Quick disclaimer: I'm...
494
Hello, has anyone ever been caught in this situation? You have redundant CPUs, fieldbus is PROFINET, there are some devices which don't have the...
502
