Designers & Customers
Aabeck
Feb 2013
Detroit
1,860
I have to rant about this one.
Called for a press not being able to unload - so it had to a PLC problem. Traced it to a bad cable going to a photoeye that terminates in a junction box on the side of the press.
Just look at the photo..............................
And - there is a screw in the lower left corner of the box that has about 1/2" between it and the main cabinet
Needless to say the replacement cable does not run to that box with the main cabinet right there.
It's obviously a safety feature. There is some very dangerous 'lectricity in that there box! I mean, just look at the sticker! We have to protect people from all the volts!
Yes, there is.
480V going to a 15HP hydraulic pump, a 7.5HP vacuum pump and a 5HP door winch
And this system has 4 presses aligned in a row setup identically
Excellent! So they're all very safe then! Well, electrically, I mean. They could probably still take your arm off mechanically, but at least you won't be electrocuted while it's happening.
…what are some key areas that you would discuss? I have a distant friend who owns a mechanical design shop with roughly 10 designers working...
2,741
I know that someone here, at some point, has been involved in the design of whatever machine it is that twists bread bag ties. Please, for the...
2,340
I've currently writing a best practices/guidelines for a system I'm working on. The system consists of eight Guardlogix processors connected over...
2,538
I have been attending a concrete block making company for 30 years. I have detested every second on site. In winter the yards are 6 inch deep in...
25
5,210
(Rant)(CAD Models): Phoenix Contact Took the Time to say "FU!!" to their customers So obviously they have real CAD models of their parts because...
1,757
