Sorry, but there aren't any alternatives to using the floppies, hoever, tThere are a number of floppy image copiers available and they are quite cheap and work for Rockwell software keys. I must stress that these should only be used for backup purposes. Any other use is a violation of your license agreement. So if you have one license, you can only use that key on one PC at a time. Alternatively, if you suffer a loss of your key while in transit, Rockwell will provide you with an entry code to restore the key.
Try the floppy Image copier at
http://www.rundegren.com/
