AB 1756-L74 RSLinx Driver
blawrenz
Jul 2006
Kansas City
22
I am using one of the new Rockwell 1756-L74 processors. The processor does not have the RS-232 port that I am used to on the older processors, it has a square USB port. Does anyone know what driver I need to utilize in RSLinx to communicate to this processor. I am using RSLinx Classic Rev. 2.57.00.14 CPR9 SR3.
Thanks,
Brad
Try to select a SmartGuard USB driver from list of available drivers, under communication-configure drivers
Thanks Val!!
FYI for anyone interested. Rockwell indicated to me that RSLinx 2.57 has an automatic USB driver that once it is plugged in it will automatically see the processor. They also referenced me to Answer ID 74768 if you have access to the Rockwell Knowledgebase.
At Tech-ED they suggested that you just plug in the USB cable and the driver automatically loads.
Edit: Man I'm slow, 2 minutes for me to type one line!
Dear All, We are designing a solution with 1756-L74 and Archestra. We need to use SOE to show on HMI. Please mention any solution if someone did...
147
Hi Guys.... I am facing one issue. PLC Controller i.e. 1756-L74 is now showing the error as T03:C16 IO connection Failure.... What can be reason...
1,637
We are in the process of converting our plants from PLC5 controllers and 1771 I/O into ControlLogix PLCs and Logix I/O. Up until now we used 1756...
32
Hello all, I have a 1756-EN2TR dual-port Ethernet IP Module attached to my 1756-L73 PLC. I currently have hazard symbols over both the top and...
60
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
99
