Studio 5000 v31 IP address offline
stu
Aug 2005
England
783
Hi guys
I have a program with is written in studio 5000 v31, which I’ve had to download the latest version to open ?
I have 2 question , am I right in thinking that in the new studio developer you can write your program and have your hmi in the same project ? I know Siemens do that but I thought rockwell have done it to ? If so how ?
And 2nd where is the processor IP address stored in a offline program?
I can’t find it anywhere the processor is 1769-18ER thanks Stu
First question: kinda-sorta-not really.
Studio 5000 is *almost* like TIA portal in that it has Logix Designer (the PLC programming software) and View Designer (HMI programming software for PV5500 series only) within the same package, although they still both open up as separate programs. If you're using any other type of HMI/visualisation that uses FactoryTalk View, then you still need FactoryTalk View Studio. You can launch the FTView projects from within Studio 5000, but it's a completely separate software package with its own license.
Second question: The PLC's IP address is not stored in the offline program. The PLC program doesn't need to know the IP address, only the hardware.
That said, you *can* set the communications path to the PLC and save it as part of the project. That's just a convenience thing so that the file remembers which driver to use and which path to take to get online next time you open it - it's not stored as part of the program and downloaded to the PLC - but if that's been done then you'll be able to see the entire communication path, including the IP address.
Hi everyone: I need to upgrade my Studio 5000 to from V31 to V33, but when I try to download from Rockwell PCDC, I only have the option up to 31...
1,389
Guys, beating my head on a wall here. I have two simple date-times and I want to find the oldest. Are there any better ways to do this beside a...
3,491
  • Poll
Hello Everyone, Is it a good idea to make the switch from 31.011 to 32 or 33? I am currently using 31.011 on all of our 5370 L33 or L36...
7,771
When starting installation of Studio 5000 I get option to install it on C: disk as default. When I change it to disk D: I see that it still wants...
2,924
I am trying to add datalinks to a couple of PF525 drives in studio 5000 V31 in order to use the PlantPax AOI. I am offline with the PLC and the...
3,685
