PLC PROGRAMMING AND HMI CONFIGURATION CHARGE AMOUNT FOR 50 I/Os PROJECT
IdealDan
May 2017
MA
480
Hi guys,
Please I need a rough estimate or idea rather (in USD)
For a PLC Programming and HMI screen design/configuration contract Project of 50 I/Os,
HOW MUCH WILL BE AVERAGE CHARGE FOR THE PROGRAMMING (separate) AND HMI (separate).
INFORMATION:
This is Oil and Gas sector.
Please ignore Project continent Location. Assume an average estimation please.
Thanks in Advance
How can you?
In USA or Malaysia and if USA it would depend on where TX does not charge the same as ND, I dont think you can just come up with a number without a lot of questions answered
You should look at it in 'time' then apply your cost per dollar to the 'time', here are a couple of threads that may help you consider the time
http://www.plctalk.net/qanda/showthread.php?t=4272
http://www.plctalk.net/qanda/showthread.php?t=86678
There are many others
30 min per DI/DO and 1 hour for AI/AO.
So if all 50 IO is discreat digital.. 25 hours for the PLC and 25 hours for the HMI.
Use your cost per hour.
Usually not far off for me. Although you may want to factor in for documentation, commissioning, etc...
Thanks Bro.
Could you please suggest an average hourly pay (May be using your location as reference)?
Regards
I don't know how it would help him either, I'm sure pay and charges differ wildly between Europe and the US.
Surely he knows how much his company charges?
Thanks Bro.
Search Bro... :rolleyes:
Did you even click on the links I put up? a lot of people posted their hourly rates but its too wide of a range
How can you?
Sorry Bro, Oversight here.
I didn't see this.
One thing you MUST consider !
the hours quoted are from members who have been doing programming for years. They don't have a learning curve.
we don't know your application.
we don't have a scope of work or sequence of events.
we don't know your programming software, interface, or hmi.
we don't know your programming experience and capabilities.
I don't mean to be rude or mean, but you must look at the process, scope of supply and sequence of events, safeties and plc interface to other systems, manual controls, documentation required, commissioning, prove out, and your own capabilities and come up with your own time estimate.
if you quote 50 hrs based on what we tell you and it takes you 60, that's ok, you were close. but if it takes you 200 hrs for example, then that's another matter and I don't know how to over come it because you went by what we would quote based on none of the information I have listed. if we had all the information, our time may have gone up to 200 hours.
as I said, look at all the information and come up with a time frame that you are comfortable with.
james
Other factors that have a big impact on price: some mfg firms have PLC & HMI template that have to be used/followed (GM & Ford for instance) and have plant communications that have to supported. Or safety PLCs must be used. These customer requirements can't be accounted for just by the quantity of I/O. Know your customer and their expectations.
Hey Guys, I am looking to bring some new guys onto my team and I was pondering the idea of doing a basic test just to weed out some peoeple that...
17
2,868
Hi Everyone! For those who used to program or familiar with PLC and HMI programming that follows the standard for packaging equipment...
4,559
hi, How to get home based PLC & HMI programming projects? thanks
3,283
hi, is there anyone in this forum who works PLC,HMI,SCADA programming projects as a online freelancer? thanks
1,294
I have been asked by a engineering firm , that is shorthanded , to write a PLC program ,do a HMI application and commission a 20 tank fill and...
3,979
