Proface help needed
stu
Aug 2005
England
783
Hi
Basic question how do I rotate a mixer blade in go pro ex
When a button is pressed ,I can get It to turn (flip) but mot rotate
Any ideas
For rotate you need to config animation at object then assigned word address that shown position angle and use some script to change value to rotate. I have attached sample program to rotate rectangle. You can modify it to your project.
thanks for that , its much appreciated
I cant open it though as I have version 3 software ?
is there a way I can covert to version 3/
thanks stu
thanks guys
I have opened it ok, so thanks again , its not what I meant I have a paddle on a mixer that I would like to understand how I can make it look like its mixing
any ideas
thanks guys
any ideas
You need to create animation object into multiple frame first then use Image Registration in GP-Pro EX to embeded image into touchscreen by follow this link
https://www.hmisource.com/otasuke/download/seminar/PFTR07_CLS01REVB_Ch27_Images.pdf
Then create Picture Display and select State Display after that you input word control parameter and Select Display. You should create script for animation too.
I have attached example project for V3.00. Please check it.
Thank you that makes more sense , I take it I add the different pictures states to on display and the opposite state to off display ? Thanks
Hi Good people I hope your all well and can help me with some info ,Im just about to start a project on a proface screen and need to learn on...
2,019
i need HELP, Hello everyone i have a problem like this, i made just two buttons letter A and B in my Hmi proface AGP 3200 , and i make a simple...
1,843
Hello all, I am in my first year of programming and stuck up on a few things for a project that needs to be completed this week. My boss and...
735
I'm looking for the older Proface software.PB-III I have GP-PRO-EX already. On their website it lists it but nothing about purchase or download...
1,955
Hello, I'm working with an already developed system that uses enhanced recipe on the HMI. I'm looking for the control word to allow the PLC to...
4,843
