Dariusincj
I'm looking for a cheap way to pull data from a controllogix system to a SLC504 so that I can use the DH+ connecting on the 504 which is connected to a historian system (along with 15 other 504's). I know that a 1747-AENTR can be used to replace the processor of a 504 but can it be used to read/msg from a controllogix to a 504 processor? I know that an AN-X2-AB-DHRIO can be used to read DH+ through Ethernet connection but it can't be used to read Ethernet through DH+ connection or I would use it. Rather than installing or changing a machine over to compactlogix from controllogix, I'd rather just try to read the data. Even if I have to msg from a controllogix to a data file in the 504 and then read that through the DH+ connection to my historian system. Any suggestions?
