Siemens S7 300 CPU 315-2 PN/DP + CP 342-5 + ET 200SP + SIMOCODE + ABB VFD
renishrudani
Nov 2016
Surat
I have a Siemens S7 300 CPU 315-2 PN/DP PLC and CP 342-5. IM Module is configured via ethernet port.
I have two profibus network. One on CPU and Second on CP Card
20 Simocode and 5 ABB VFD which is configured on CPU. All things is working ok which i have configured in profibus network on CPU.
the problem is that, I have other 15 Simocode and 3 ABB VFD that are configured on CP Card. but network isnt be healthy and i'm not getting data from CP Card profibus network.
I have written 2 network of DP_RECV and DP_SEND.
Please help me out. What to do? if you required project backup then also tell me.
What is the reasoning behind having the second DP network?
Why not have one network, and get rid of the CP module?
If the network isn't healthy, then I'd start looking there. What speed are you running at? Have you checked the cables to ensure they are properly grounded and terminated?
Hi guys, looking for some advice from someone with some siemens hardware experience. Im a student considering buying a siemens plc to practice...
5,044
Hi Guys, I am facing a problem with my Siemens Simatic S7-300,CPU 315-2 DP( 6ES7315-2AF03-0AB0 ).That is in the morning i dont know why but it...
3,352
Dear sirs, Currently i am working on a project which requires to connect the plc ethernet port to monitoring devices, for your information the...
8,013
I did a little bit of sercing here and on Siemens site for a communiication cable between an S7-300 CPU and PC's USB port. However there are...
2,136
I have a string that I need to remove six numbers out of and move to an Array. I can't seem to find anything that will work for me. I tried a...
3,098
