Connection Problem between AB control logix and Citect Scada.
james84
Apr 2010
melbourne
hi,
I having trouble communicating Citect SCADA and AB Control logix 5561 via Ethernet module 1756 ENBT.
i am able to ping the PLC from my SCADA computer.
i am using ABCLX driver in citect and when i type port ip 192.168.254.xx and run the project coming as hardware error..
i don't know where i am going wrong.. is there port address should be 192.168.254.xx/Backplan/0?
if any one have a idea, please help me with this problem.
thanks....
This will only point it to the ethernet card not the processor
Try 192.168.254.xx/0
Hope this helps
Hope this helps
thanks for reply,
i tried 192.168.254.xx/0, 192.168.254.xx/Backplane/0 but still getting the same error.
please help me with this..
Did you follow the Express IO device Setup? did you change anything else under "Ports" except for Special OPT?
dont think you need a /0 if your CPU is in Slot 0.
citect version?
Search the Citect KnowledgeBase for ABCLX.
There are some tricks where you need to sort the Variable.dbf by UNIT first then TYPE.
Also if there are some bad tags/not defined in PLC then you will have connection errors.
See the info in the Knowledgebase.
Citect to CLX is not simple to do the first time.
Comms set up is as per help files and as below it works.
192.168.254.xx/0
citect version?
thanks mate,
i am using v.6..... my cpu is on slot 0, i tried "/0" and without 0 as well...
i am not changing anything in ports except special opt.192.168.254.xx
only in special option do i have to enter ip or anywhere else aswell?
192.168.254.xx/0
thanks mate..
i have gone through knowledgebase tutorial....couldn't help me..
i want to use very few tags from plc to SCADA... (9 out of 380 tags) is that make any difference?
i have plc program created by someone else.. i export all tags as .CSV and then copy tag name and address direct to SCADA variable tags whith necessary TYPE and ".,_" changes..
is this the right procedure?
HI every one , I'm trying to connect two cpu's in siemens step 7 I followed all steps7 in this video https://www.youtube.com/watch?v=-qnvwz8nlRQ...
2,632
Hi all, I am trying to load a program to a simatic panel I have set up the ethernet communication so that both my pg and my panel have the...
2,389
hello. i have one problem...this project work fine for one month and when i start the computer it works fine but now he show an error in...
963
I have a problem in terms of inputs and outputs, when I create a tag for a variable% MW1 and I run it . i had a BAD display for my tag. So my...
4,560
Hello Everyone, I am being unable to connect my laptop & GE Quickpanel (IC754VGI12CTD) through an ethernet cable. But I could connect the same...
18
6,432
