Can't upgrade firmware for CompactLogix L32E
mabauti
Sep 2017
Bahamas
Hi everybody
I hope you can help me.
I´m trying to upgrade the firmware , but dont get sucess. This is the log I get from ControlFlash:
9/11/17 16:18:23 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
09/11/17 16:18:52 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/11/17 16:18:54 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/18/17 12:21:59 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
09/18/17 12:22:03 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/18/17 12:22:04 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/18/17 12:22:14 [FAILURE] Device Identity: Error #11003: Unconnected Send timed out waiting for a response.
GS=0x01, ES=0x0204
09/18/17 18:16:09 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
09/18/17 18:16:12 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/18/17 18:16:13 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/18/17 18:16:18 [FAILURE] Device Identity: Error #11003: Unconnected Send timed out waiting for a response.
GS=0x01, ES=0x0204
09/25/17 12:00:43 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
09/25/17 12:00:48 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/25/17 12:00:48 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/25/17 12:08:33 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
09/25/17 12:08:35 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/25/17 12:08:35 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/25/17 16:32:40 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
09/25/17 16:32:43 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/25/17 16:32:44 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/25/17 17:14:36 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
09/25/17 17:14:45 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/25/17 17:14:45 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/25/17 17:14:49 [FAILURE] Device Identity: Error #11003: Unconnected Send timed out waiting for a response.
GS=0x01, ES=0x0204
09/25/17 17:14:59 [FAILURE] Device Identity: Error #11003: Unconnected Send timed out waiting for a response.
GS=0x01, ES=0x0204
09/26/17 12:09:37 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
09/26/17 12:09:39 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/26/17 12:09:40 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/26/17 12:10:06 [FAILURE] Device Identity: Error #11003: Unconnected Send timed out waiting for a response.
GS=0x01, ES=0x0204
09/26/17 12:10:29 [FAILURE] Device Identity: Error #11003: Unconnected Send timed out waiting for a response.
GS=0x01, ES=0x0204
09/26/17 15:32:26 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
09/26/17 15:32:29 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/26/17 15:32:29 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/26/17 15:32:33 [FAILURE] Device Identity: Error #11003: Unconnected Send timed out waiting for a response.
GS=0x01, ES=0x0204
09/26/17 15:33:52 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
09/26/17 15:34:11 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/26/17 15:34:11 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/26/17 15:34:14 [FAILURE] Device Identity: Error #11003: Unconnected Send timed out waiting for a response.
GS=0x01, ES=0x0204
09/26/17 15:44:13 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
09/26/17 15:44:18 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/26/17 15:44:18 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/26/17 15:45:06 [SUCCESS] Device Identity: Path = RSLinx API!AB_ETHIP-1 16 13 49 57 50 46 49 54 56 46 49 46 49 48 51 0 1 0, Instance = 1,
VID=0x0001, PT=0x000E, PC=0x004D, Maj Rev=01, Min Rev=15, SN=0x403D01BE
09/26/17 15:45:27 [SUCCESS] Validate:
09/26/17 15:45:27 [SUCCESS] Authorization: Bypass cookie used.
Key: PN-133555
09/26/17 15:45:52 [SUCCESS] Device Identity: Path = RSLinx API!AB_ETHIP-1 16 13 49 57 50 46 49 54 56 46 49 46 49 48 51 0 1 0, Instance = 1,
09/26/17 15:45:56 [SUCCESS] Validate:
09/26/17 15:45:56 [SUCCESS] Authorization: Bypass cookie used.
Key: PN-133555
09/26/17 15:46:03 [SUCCESS] Load Script: C:\Program Files (x86)\ControlFLASH\0001\000E\004D\PN-133555.nvs
09/26/17 15:46:03 [SUCCESS] Program: Catalog Number = 1769-L32E/A LOGIX5332E, Serial Number = 403D01BE, Num Updates = 3, Size = 6243840 byte(s).
09/26/17 15:46:09 [SUCCESS] Update: Instance = 3, Size = 2836168 byte(s), Chunk Size = 128 byte(s), Major Rev = 20, Minor Rev = 11
09/26/17 15:52:27 [FAILURE] Reset: Error #11003: Unconnected Send timed out waiting for a response.
GS=0x01, ES=0x0204
09/26/17 15:52:35 [FAILURE] Reset:
09/26/17 15:53:54 [FAILURE] Update: Error #11003: Unconnected Send timed out waiting for a response.
GS=0x01, ES=0x0204
09/28/17 17:12:59 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
09/28/17 17:13:04 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/28/17 17:13:04 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
09/28/17 17:14:12 [SUCCESS] Device Identity: Path = RSLinx API!AB_ETHIP-1 16 13 49 57 50 46 49 54 56 46 49 46 49 48 51 0 1 0, Instance = 1,
VID=0x0001, PT=0x000E, PC=0x004D, Maj Rev=20, Min Rev=11, SN=0x403D01BE
09/28/17 17:14:16 [SUCCESS] Validate:
09/28/17 17:14:16 [SUCCESS] Authorization: Bypass cookie used.
Key: PN-133555
09/28/17 17:14:22 [SUCCESS] Load Script: C:\Program Files (x86)\ControlFLASH\0001\000E\004D\PN-133555.nvs
09/28/17 17:14:22 [SUCCESS] Program: Catalog Number = 1769-L32E/A LOGIX5332E, Serial Number = 403D01BE, Num Updates = 3, Size = 6243840 byte(s).
09/28/17 17:14:24 [SUCCESS] Update: Instance = 3, Size = 2836168 byte(s), Chunk Size = 256 byte(s), Major Rev = 20, Minor Rev = 11
09/28/17 17:18:55 [FAILURE] Reset: Error #11003: Unconnected Send timed out waiting for a response.
GS=0x01, ES=0x0204
09/28/17 17:19:02 [FAILURE] Reset:
09/28/17 17:20:21 [FAILURE] Update: Error #11003: Unconnected Send timed out waiting for a response.
GS=0x01, ES=0x0204
09/28/17 17:34:22 [-------] User must install FactoryTalk AssetCentre Client 2.31 or above if attempting to log message to FactoryTalk AssetCentre Server.
The first package is sent. The PC "lose communication" after the power up operation
Thanks in advance
Opening observations from the log file...
You are attempting a flash using the Ethernet port.
The 1769-L32E processor is flashed to firmware revision 20.11 - 1st part, then first reboot fails.
What is most likely happening is that ControlFlash is attempting a "Polling for powerup", which automatically reboots the controller, and the Ethernet port's IP address configuration is being reset. This often happens when a Static IP address has not been assigned and BOOTP is still active.
Can you verify whether the Ethernet port's configuration is Static or not? Have you or are you disabling BOOTP/DHCP? Do you have to keep reconfiguring the port settings after this issue?
Browse to the controller in RSLinx Classic and right-click on it and open the module properties. Check whether the Ethernet port is set for manual configuration. If not then set it for manual and reboot the controller and check it is retaining its IP address configuration. Double-check that manual setting is still applied and then attempt another flash.
Note: For the flash, I would advise that you make sure you are connecting directly to the controller's Ethernet port and not via a switch, etc. Also, when flashing, have just the controller, the power supply and end cap fitted properly on the CompactBus.
Regards,
George
P.s. I forgot to mention that you should also disable any wireless LAN connections on your workstation.
Here is a good guide to flashing the firmware on the CompactLogix controllers...
65540 - CompactLogix Controllers: Flashing firmware via EtherNet through ControlFlash
Access Level: Everyone
Regards,
George
thanks Geospark
I can comunicate with rs232.I can not comunicate with ethernet.
I did what you told me, this is what I get (atteched image)
Done!
I did both: I had forgotten to set a static IP and assign a stable IP to my PC
Thanks a lot Geospark 🍻
Thanks a lot tarik1978 (y)
Does anybody know of a way I can upgrade a CompactLogix Module Firmware? We bought some "new" ones from EBay, but the firmware is 1.1
1,328
My Friend is in Mexico working in an older machine, he calls me because after he did a Firmware upgrade of the processor from v20 to v24 his...
2,285
I’ve got a 1769-L23E-QBFC1B with Firmware 17.1.21 and I’m trying to upgrade to ANYTHING but when I use ControlFlash it won’t show me the files and...
4,804
Fellas... Have a CompactLogix 1769-L30 5330 processor and I want to add a 1769-SDN/B to the rack. 1769-L30 processor is running v11.20 firmware...
5,878
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
112
