High Speed AI card for Local vertual backplane in SoftLogix 5800
synclogix
Oct 2003
India
Hi Guys, Any one aware of IO’s ( brand and site), that can fit into local frame work of SoftLogix 5800. One I think is Advantec. But Advantec dosent fit into the specs as below.
I have heard of NI ( national Instruments) but not sure which card and its compatibility with SoftLogix 5800
My application requires a physical PCI standard AI card with 16 bit resolution and has a fast update of about 1 to 2 ms. This card should work with the local Vertual backplane of SoftLogix
Everyone, I have an application where I need to pump a varying weight(depending on recipe) into a tank. I can't use the load cells on the tank...
1,464
I have in the field currently a high speed counter card in a SLC 505 with an encoder. There is something glitchy going on where noise is...
3,005
At my job on a specific machine the A+,A-,B+,B- inputs to a High Speed Counter Card are all connected in Series with Resistors. I don't remember...
5,456
Unregistered
U
Hi We are using an Allen Bradley High Speed Counter Card (HSCE2-1746) to count pulses from an Endress + Hauser Promass 40 Coriolis Flowmeter. We...
9,308
Do i have to use interrupt subroutine, or immediate read high speed input, for Unitronics Samba plc or reading only the correponding register in...
124
