A PLC simulator with analog input \ output emulation
KaktusJack
Feb 2008
Zagreb
Howdy!
I'm a PLC newbie and would like to know if there is a PLC simulator with Analog Input\Output emulation
Thanx in advance
KaktusJack said:
Howdy!
Thanx in advance
What kind of PLC do you want to use? I know of a HMI simulator, but if you are looking to learn PLC's then I would suggest you look at the manufacture of the largest PLC's in your area... here in the US we use more AB then anything else.
Once you find the type of PLC that you want to use, contact that manufacture (or post it here) and look that way. I think Siemens has one, its a after market made by someone else, my friend from Germany gave it to me, I don't think you can get it here in the states, but you may be able to get it.
I would hate for you to learn how to program AB or GE when you need to program Omron to get a job in your area.
Sorry, I should have mentioned the PLC manufacturer.
I am interrested in AB ( Micrologix series in particular ) because we have several at my university. I have installed LogixPro simulator and it does the job pretty well, but still i'm missing Analog Input and Output
Showing a new guy basic programming and remembered the simulator here. But nothing happens when selecting the link. "Try our online PLC Simulator-...
25
1,538
hi everyone please give me a solution to timeout error in delta plc simulator,i have a doubt about firewall and antivirus we r using.
722
I just started to learn how to program PLCs. I was searching for the best simulator programs for learning how to code PLCs. The best one I could...
3,074
I am trying to find PLC simulation software that will connect with KepServerEx, in order to learn and test an OPC UA solution. My Siemens trial...
1,392
3,768
