USB noise with a headset
surferb
Jun 2007
DC area
1,777
Slightly OT, but I'm guessing there are some experts here!
I have a pretty nice USB headset that includes noise reduction (like background noise in the room). The problem is that I'm getting a low humm that must be coming from my power supply or something. I've tried using different ports and a USB hub with no success. My recording application can cancel the noise, but it makes me sound like Kermit the Frog and sets the volume inconsistantly.
Any ideas on removing the noise? Perhaps filters, some other kind of USB switch, isolation devices, etc? Other ideas on what might cause the noise besides my power supply?
Hi, the noise is on the microphone? you say your recording app can cancel it so i assume so. Is it simply feedback from the headphones?
Cheers
No, I think it's electrical noise in the sound card/amp/whatever. I experienced a similar sound with a car audio system that wasn't properly grounded.
I don't think it's coming from the microphone. The equalizer bar on the computer shows a steady input even in a totally silent room.
On the second thought, I should play with power settings. I have no idea if the circuit is properly grounded or how I could fix that. I am powering the machine through a 220-110 transformer. My power supply is switching so the correct plug might help.
Cheers
Plugging my computer directly to the 220 socket in the wall (bypassing the transformer) fixed my problem.
If you are worried about noise there is a bluetooth mike that works off the bone movement of your ear, doesn't pick up ******t noise, anyone else talking....
H Nate,
One other thing to check, there are multiple volume controls for various parts of the system and it is possible to get noise from an input that is unconnected but has it's volume turned up. There is a "mute" function to kill those inputs that are not in use.
Bob A.
please using the usb can i assign any ip address that i want ?
148
Dear all, I have fx3u series plc with built in rs422 port and usb-sc09-fx cable. I have a a hyperterminal like application to send and receive...
219
Bonjour, Je n'ai pas de communication modbus RTU vis la configuration ci-dessus. J'ai essayé les deux mode ch1 et ch2 mais rien ne fonctionne...
160
Hello, I'm working on a protocol named "BitBus" which use a SDLC protocol for encapsulation. This protocol contains start & End Flag, but when i...
152
Hello all. My rslinx freezes for several minutes each time a USB device is browsed. I thought I was freezing indefinitely, but disabling...
603
