.DNO files to PDF
jgunnels
Jun 2010
Vancouver Washington
24
I have a need to look at Powerflex 700 parameters from backups from years ago using Drive Explorer or Drive Executive? they are .DNO and I have CCW 12.0 which will not open them. is there anybody who can help to extract the parameters to PDF?
I have tried to attached here but there is a limitation on ZIP of 397.7k they are 1,104k
Or should I just try and Locate an old copy Drive Exec/Explorer?
in advance
Joe
in advance
Joe
PM me your email address, I'll see if I can help you out.
CCW can import *.dno files, you go to File/Import Device/Drive File when the search box opens use the file type drop down to select .dno and then import it and as long it is a drive supported by CCW it should import.
Alan
Alan
Huh, I'll have to try that. While I have CCW, I don't really use it. Thanks for the tip
Can someone do me a huge favor and print these 2 Allen Bradley DNO files and email them to me? [email protected]...
1,756
I am currently working on a site with a faulty Powerflex 755, we have a replacement but have no access to the parameters with no license for...
149
Can someone with Drive Executive please save me a printout of the parameters for this drive in this file. I'm in a bind and would greatly...
362
Would anyone be so kind as to open a dno file and print the settings for me to enter via the keypad. We had a drive go out here and I'm trying to...
1,191
Was trying to open a .dno file and a diaolge box open saying that it was NOT a compound file........What does that mean??? looked on AB site but...
1,666
