how to calculate the power to a 3 phase delta connected heater if the load is not bal
mahipatsinh17
Oct 2012
OHIO
Hi guys
I was asked how to calculate the power to a 3 phase delta connected heater if the load is not balanced.
know the formula W = LV x LA x 1.732 x PF for 3 phase power but I can't remember how to do the same for an un-balanced load.
please help me out
No its not sinusoidal current, othervise i think the average power dissipated by the load is calculated from an RMS voltage measurement.
I want to calculate the energy consumed from instantaneous power. Can this be done using the TOT block with timebase set to Hour?
689
I want to calculate power - I know amps, voltage but not power factor - on a single phase max 50A circuit. There is a mechanical KW meter at the...
2,621
Hi gentelmen It is a pleasure to join you and discuss some information about hte PLC.Where i will graduate from the college this year and my...
1,755
Hi guys, May I know how can I calculate the total current consumption for 1756-PA72 power supply? My input is 240V AC. I'll use input power...
5,023
Hi guys, I'm designing a DeviceNet network using rounded thick cable (max. 500m). I'm browsing thru the manual stated that the current...
7,288
