Hi all,
This is a newbie question: what is the proper use of a Disconnect and ground conductor disconnect terminal block?
I've read that these terminal blocks are very helpful in testing analog i/o cards. Are there any other uses? What is the proper way to wire them?
For instance, if I have a 4 ch analog input card, would I use one terminal block for each channel? Or just one at the incoming vdc fron the power supply? The model I have comes as 2 terminal blocks joined by a jumper. It appears that the positive and negative connect at one end... Any tips for best use of these terminal blocks?
Below is a picture of the terminal block I'm talking about:
Thanks in advance!
Thanks in advance!
