Citect Scada Variable Tag Formating
Chickenmann
Sep 2012
Adelaide
I am having trouble with Citect displaying a variable tag in the incorrect format.
I have a tag (MC1_Input_temp) setup as a int with a format ##.# within citect. I have created a text field on a page with numeric expresion formated ##.#
The issue is when it is displayed the decimal point drops off. ie 186 when it should be 18.6. Im guessing I will need to do some kind of conversion
You will need to scale it on the tag
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
232
Excuse my inexperience with cicode, I have a citect issue I need to make "Global" where the line below is shown in bold in the below function...
3,167
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
269
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
219
Hi All, I aim to use Aveva Plant SCADA 2020 to read and write data from/to Omron CJ2M CPU35 PLC using OMFINS protocol. However I have Bad Data...
686
