confusion about Rockwell software Studio 5000 Revision
Usama_maqsod
May 2016
Lahore
29
Dear All,
I am confused in a situation and I am sharing the problem statement in detail,i hope it will be fruitful as in past:
I have a Allen Bradley Control Logix 1756-L71 controller with I/O cards.It has been Programmed by some Previous Engineers using Studio 5000 (Software version is unknown).
Client wants me to prepare a spare Allen Bradley Control Logix 1756-L71 controller for unexpected situation.
I have Studio 5000 software having revision 24.00.and also the backup file(L5k) of downloaded program.
when i tried to open the file in my software Studio 5000 rev 24 then a pop up appeared that this program is on version 21.1 please import it and 2 options came out in drop list for selection 20 or 24.
Firstly i tried to import it in 20 but failed then I selected 24 and process started.
After taking 2 to 3 minutes Program was on my laptop screen.I checked the version of CPU it was 24 written there.
So,Now here it is the question that whether i should just download this program to the NEW CPU,and after download will it become the Plug & Play replace able for already installed CPU?????? :unsure:
Sounds good to me... just make sure you can go in on a weekend and change out the processor while they are not running, if there are issues you can swap the other one back
If you have a support contract with AB you should be able to upload the 21.1 from their website and keep the new CPU to that version, I think that would be the easiest, then your customer would have both the backup and running with the same version
Hi, The company I work for has just purchased RSLogix 5000 professional edition & Factory Talk View Machine Edition. The packages contain loads...
6,093
Hello, all, I am new here and pretty new to PLC'S. Closest thing I have to PLC experience is with avionics. At my new job I am a welding engineer...
786
I am working on some documentation in preparation for updating firmware around our plant. On one particular PLC, the point IO has two different...
689
When enabling a FOR instruction does the index set to the initial value before the first execution of the Called Routine? e.g. Initial Value = 6...
1,460
Hello, My apologies in advance if this is a stupid question. I have done a fair amount of work in Factorytalk View machine edition, and I am...
1,218
