Indirect addressing in UDTs and Arrays (Logix 5000)
rrparker07
Jun 2010
Winston, GA
89
Need a little help with my son's AP Statistics project! I am writing some code for my son to test reaction time variance based on music volume. He is testing 6 subjects at a time, 3 male and 3 females. Each subject get 3 tests at different volumes and there are 10 reaction recordings for each volume. He has to test a total of 36 students. I"m trying to limit the amount of code I have to write for this.
What I've planned so far is using 6 "running test" arrrays for the current test. I created a UDT called "Treatment Log" for each of the 36 students. The UDT has the 3 different volume arrays with 10 elements each. What is the best way to get this info to my storage locations? I was going to use the COP instruction but I couldn't see how to point to the right place.
Thanks in advance for your help!
I guess the way to do this is with indexed not indirect addressing. I'm still doing something incorrectly as I am getting an "invalid array subscript" error. The syntax I used is test_array[Y] with test_array defined as dint[10] and Y is a dint. I dunno.
Figured it out. I created my tag reference y at the bottom of the "edit tags" screen and it still had the asterisk on it. We are good!
Howdy folks, I am an Allen Bradley guy currently living in an Emerson world. Working with Rx3i on PacSystems Machine Edition v. 9.6? i think...
620
Hello, I'm very new to programming with absolutely zero schooling in this field and pretty hands off training in my new role, it's been fun...
668
Hello Friends, I am trying to index M Bits, however GX Works2 is not allowing it with following message. https://ibb.co/zPcqj6M...
1,378
Hi All, which the best way to do the indirect addressing in an optimize DB? Ccurrently this is my partial code inside an FB...
2,273
Hey everyone, Just used the PLC5/Logix migration utility to convert a program, and while addressing the PCEs, I noticed a lot of errors for "XIC...
1,972
