A-B FactoryTalk ME 8.20 Macro Programming
delforum
Jul 2014
US
Hello PLCTalk Geniuses,
I have an issue with my ME application. When the HMI is not communicating with my PLC and I try to shut down the application, the marco I tied to the Global Connections>"Remote Macro 3: = system\BlinkSlow" continues to run and won't allow the application to shut down.
Inside the "Macro3" I have the following lines:
Line1. {[PLC1]HMI_PULSE} = NOT {[PLC1]HMI_PULSE}
Line2. {[PLC1]HMI_ACK_BUTTON_1} = 0
Line3. {[PLC2]HMI_ACK_BUTTON_2} = 0
If communications between PLC and HMI are good, it shuts down fine. However, if I don't have communication between the PLC and HMI this macro hangs keeping the application open. The only way to shut it off is to pull power.
How would you suggest I modify the Remote Macro 3 line or the Macro3 sequence so it will stop when there is a comms failure so I can shutdown the application?
Thank you,
Del
Hello, I am fairly new to AB PLC and HMI. I am using Factorytalk View to create an HMI application. While using Macros, I wanted to create a...
2,394
Hello all I have a question, concerning datalogging in FTViewSE 8.0 I have 2 datalog models with 2 differents recording rates (30s for live...
2,761
Hi every body. We have an windows based HMI installed with factory talk SE studio in which we have copied our previous factory talk backup. In...
4,624
Hi all, I have a question about the macros in FactoryTalk. When I download the runtime file to the PV+ 700 and run the program, every time the...
2,290
Is there a way to create a Macro that is executed when a display is opened. I know how to create a Display_AnimationStart() routine to execute...
6,480
