Logix 500 Array Navigation
stormsabove
Mar 2018
IL
Hello All,
I have an array (n10:0 - n1-:110) filled with values starting from 10 and counting up. N10:0 == 1, n10:01 == 2, so on and so forth.
I'd like to move the value from n10:0 to N7:0, then 30 seconds later move the value from n10:1 to n7:0. Then 30 seconds later n10:2 to n7:0. etc.
Then, I'd like it to step back down every 30 seconds until I say stop again.
I won't always start from N10:0, and I won't always stop at N10:0.
Any advice is greatly appreciated!
Welcome to the forum!
I'm having a hard time understanding what you're trying to say here. Can you clarify? If you can explain the purpose of this logic/array as well, it could be helpful.
Hello, I'm using a counter as a timer to get a time value to get the current cycle time and last cycle time. I need to put this "last cycle...
2,777
Hello all, I am trying to make an array so that each time a button on my touchscreen is pressed, my program records the date, time and a counter...
23
18,495
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
82
buen dia. tengo una falla al pasar los tags de mi plc SLC 5 0/4 a mi panel me aparece un error Problem writing value " " to item <tag name>...
73
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
98
