Rslogix 5000 - structured text- TONR instruction
italo2008
Feb 2009
Padova
95
Hi. could someone give me an example about TONR instruction in structured text?
I need to build a sort of "clock" wich set a bit at each second... Someone told me that I could do it with tonr instruction...
thanks
Unless you know what you want, and describe it better, there is absolutely zero reason to use the TONR instruction for a one second timebase.
In fact, with a real time clock available, there is no reason to use a timer instruction at all. Create an array of 7 DINT's, and use a GSV instruction... GSV WALLCLOCKTIME LocalDateTime MyDINTArray.
MyDINTArray[5] is seconds. Do something every time it changes.
Hello, I please need your help why I cannot get the return parameter from the RET instruction to go into the return parameter in the JSR return...
2,739
Hello All, Please how can i edit a structured text program in rslogix 5000. Thanks
5,244
I don't use structured text too much, but wanted to loop some items, so i thought i should try it. Got a hang up. What i am trying to do is to...
4,710
Hi, I Am trying to modify a Vendors program here on site and have just purchased Rockwells SFC Editor licence to add to my RSLOGIX 5000 ver13.02...
6,683
Hello all, I have a question in regards to RSlogix 5000. I am having issues with the program force closing when I try to make online edits. We...
95
