AB CCW: Downloaded UDFB has password??
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
I'm trying to use a 2080-MOT-HSC (high-speed counter) in a AB Micro850. I downloaded the UDFBs, and imported the function block that would suit my purpose.
As you see in the attached picture, that function block is locked, and I'm prompted to enter a password. ....what the heck! There is something wrong here. I can't import any of the UDFBs without them being protected. Surely someone else has experienced this and can help me figure out what's wrong.
Brian
It's been a long time since I encountered this, and I don't use CCW much. But I believe those are established function blocks, and you're only working with the variables that are assigned to the block. You don't need a password.
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
59
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
224
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
165
I am new In a CCW and as a beginner I am trying to learn programming but i am noticing that my CCW software is taking around 1 minute to download...
100
