Recommended RPI
the_msp
May 2008
Northern Ireland
1,271
Hi, I have a 1734-AENT with a single card in the rack (1734-4IOL). I am using two channels for control/feedback of DC stepper drives.
Based on the following info, is there a way to determine the best RPI to set?
Protocol IO-Link (Version1.1)
Communication speed COM3(230.4kbps)
Communication cable 4 wire unshielded cable (conductor resistance 3 ohms or less, line
capacitance 3 nF or less, length 20 m or less).
IO-Link port Class Class A
Setup file IODD file (Download from SMC web site).
Process data length Input 14 bytes / output 22 bytes
Process data
minimum cycle time 2.4 ms
Vendor ID 0x0083
Device ID 0x00013E
Network topology 1:1
SIO mode Not applicable
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,135
Hello all, I have a client that needs to externally control some valves at a small plant, nothing fancy. (for which I just need digital IO)...
16
3,925
We are going to be using a SIRUS 3RW5545 Soft Start to control a 480V, 150HP fan. Looking for some recommendations for parameters to use with this...
846
Good Afternoon , I'm getting ready to lease a lot of Rockwell Software. I really don't have any desire to go the VM route , just because I'm...
2,014
I wanted to get some opinions and maybe a point in the right direction for products on networking machines for data collection. Im not all that...
4,844
