Direct Logic
jwtdjt
Feb 2007
Kentucky
I have a direct logic DL05 PLC. I need to program in 2 timers and I have never used times before. I want the unit to be on and cycle off after 90 minutes, then cycle on and off every 15 seconds for 30 minutes. These timers are nothing but confusing to me. I am using DirectSOFT software..
Can you translate your discription to ladder logic?
jwtdjt,
Is there a input to turn on the "unit"? Like a selector switch maybee?
Is there only one output? With the hundered word limit software there won't be room for much more.
You want 90 min of time and in that time you want the unit to cycle on for 15 sec. How much off time do you want? And you want the off and on cycle to run for 30 min What about the remaining 60 min of that 90 min time, what are you wanting to do with that?
At risk of being beat into submission, beyond any chance showing my face in the great world of plcs.net ever again, and/or any risk of people laughing, fighting, loving or any other thing beyond my control…I will take a stab… there are many ways that this logic can be done, also there are unknown variables that have not been discussed.
part one...
part two...
Damn you have to go through a lot of **** just to write a little code....
BTW...I think it would work, but you would need to debug it :D
I want the unit to be powered on for 90 minutes. After that 90 minutes, I want the unit to cycle on for 15 seconds, then off for 15 seconds, on for 15 seconds, off for 15 seconds, for a total of 30 minutes. Total time for the program is 2 hours.
Yes, there is going to be a reset switch. And I would like to have this program run on 6 outputs. However, one would be a start......
So... input on part two is ct10 which starts timer T0. I will debug and give it a shot. Thanks a million. I have never used timers before and I am having a killer time getting this to sink in.
Thanks again.
You can post your code here after you write it...we will help you trouble shoot it (debug), the AD manuals are very good, they are free in PDF format from their website, but I find it easier with the real coppies
Hope your project tunrs out good...
So this is my attempt at collecting and displaying data on a Cmore panel With a DL06. Each pair in my logic is the "Time total" or the TA15 and...
475
Hello, I am having some trouble trying to use Port 2 on the direct logic (250-1) for K-sequence. I am trying to use RS-232, I have a breakout...
545
I have a few o these controllers and had to replace a CPU. It looks like everything is there in the ladder including the registers for the port...
1,455
Hey, I am entirely new to PLC's and am trying to help my friend with a project. He wants to take the signal from a PNP photoelectric sensor as...
2,229
Anyone know anybody that will attempt a repair on a DirectLogic F1-130AR? There were a few hits on the internet but none I've used personally...
1,285
