Event with interval not working?
MMMcLovin
Jan 2017
Ontario
20
I have an event in factory talk view studio with an interval of 10 seconds that toggles a bit. It does not seem to toggle however. It has worked in the past. What could be the issue?
In FactoryTalk View SE events have to be turned on. Then if you make a change, you have to turn them off and then back on to see the change. Typically these events are turned on when the HMI Server machine boots up. But not always. It depends on how the programmer decided to start it.
If you can access the Command Line in Studio you can click on the ellipses button on the right (button with three dots) to access the Command Wizard which will walk you through starting your Event file.
If the event file has been started but is still not working then access the event file and grab a screenshot of the expression and action for the event you are after.
OG
This may be something obvious that I could learn if I sat down to understand the topic in detail with tutorials and manuals. But sometimes it's...
118
Hello, we have two PC with the FT SE local application and the same project. The one PC is wrong about alarm and event log. When I open the...
385
Kindly, we are having a problem on a machine during night shifts, while no engineering tool is online. So, we were thinking of programming some...
736
I have a issue with my alarm summary/banner where it losses connection to the Alarm Server. It's kind of weird because when I click on the server...
1,286
Hello Friends, I want to log FTV Studio SE alarms and event data into a oracle 12c database and as i checked the by default windows in FTAE...
809
