AB SLC 5/05 W/RIO scanner, Flex 1794-asb
Christoph
Sep 2003
Indiana
345
Due to all the recent icing from the great winter weather this past week we have experienced many power glitches. reaking havoc on our drive and plc systems. 1 occurance with the slc 5/05 remote I/O. A system with 6 surge tanks with level control. first2 were reading tank weight ok. last four
had lost weight. no longer transfering data. after toggeling to prgm back to run every thing was fine. Except while reading
0 weight the fill valve opened or was open when it locked
up and overflowed there is a high high level sensor which
was working. but did not close the valva as programmed.
My question is if a remote rack locks up
does the Flex RIO Reset to zero or maintain last state
and is this set in the ASB.?????
Been a while since I have done this but I believe the configuration of the Flex module is done in the block transfer control block. Which Flex modules are you using?
Using 1794-ASB, IB16, OB16, IEB. and there are not BTW's or BTR's
any where in the program (M) files! in the slc.
I am pretty sure you can set the dipswitches in the 1794-asb adapter to either retain last state or default to zero. Probably best to have then NOT retain their last state for the reason you experienced.
If you don't have any analog modules then you would not need any block transfers. From your original post it sounded like you do have analog. One of the modules you list is IEB. Did you mean IE8?
I have a SLC 5/03 PLC which is already installed 5 yrs ago.now im trying to add 1 input and output module to the exisitng one PROCESSOR is...
2,574
i need to communicate slc 500 with RIO and how i configure it thanks
2,294
I am using SLC 5/05 processor with remote I/O's with 1746-ASB module. The remote rack has two RTD cards. One is working OK. The another has 4...
5,884
I’ve searched the internet for answers on how to do this. But I’m in need of some help. I have a slc 500 connected to a RIO. There are two racks...
1,131
I am getting an error on my 1747 - ASB that says NOC. I looked this up in the manual and all it says is no communication. Which I knew that lol...
1,623
